here's the donkey tzar.
2165cc
78mm crank - borrowed from 56 oval
lightened flywheel - borrowed from 56 oval
weber 48 IDA carbs - borrowed from kvinyl
autolinear aluminium race case.
unitech rods 5.4"
engle W125 camshaft
scat lightweight followers
scat 1.25-1 ratio rockers
manton chrome-moly pushrods
94mm piston / barrels
cb044 cylinder heads with 40mm intake 35.5 exhaust valves.
combustion chambers reduced to 56cc.
comp ratio 9.6-1
deep sump
1 5/8" fully merged header
009 distributor
kenedy stage 2 pressure plate
cushlok clutch plate
bolt on rocker covers
26mm shadek oil pump with full flow filteration
used alternator and tinware.
it was run up on a single carb to break in the camshaft
we need to strip 1 carb, blocked passages we think.
then get it on the dyno.
