[For Sale: Parts] Swapmeet Offered and Wanted
Ive loadsa late bug stuff, dunno what I can fit in the van though! -lights,glass,etc etc
Possible pair of wide 5 banded steels, 9j.
Squareback roof rack, OEM VW
Possible flatfour style woodslat roofrack for bug.
Would have most off Madaboutbugs list there too!!
I'll see what I can fit in! - Someday I'll be as organised as Trev, hopefully he'll be sold out buy then LOL!!!!!
What are you looking for the roof racks?
Robbie
@ Paul, I just checked the loft, it's the LEFT quarterlight you need, the right one is grand
@ Deckie, I have a good right quarterlight for you (not Pauls before you ask :lol3: ). Needs the rubber in the vertical channel but have a bad left one (not Pauls ;) ) you can use to salvage the rubber out of
@ Ross, I found a thermostat for you and I also have that flat piece of tin for under the thermostat. No "between cylinder" tins though.
@ Liam Beetlebug, have a flat piece of tin for you too.
@ Britt, have a doghouse shroud for you
took loads of photos and made a rough inventory. more to come...
ok, here goes: prices are a guide, if you buy multiple parts I'll do a job lot price. If I owe you a favour parts will be free or as close to free as possible ;) I'm anxious to clear a lot of this stuff and just get rid of it.
all parts are in used condition and are for '70s beetles unless specified otherwise in the listing.
5x steering boxes, 3 without pitman arms, 1 with RHD arm, 1 with LHD arm
6V starter motor Spoken for by Deckie
2x oil bath air filter
1x good RHS quarterlight Spoken for by Deckie
pair of dodgy quarterlights glass is perfect though
1x trim piece for under late bay rear bumper
2x wiper motor/mechanisms
type 3 engine hanger bar
2x Europa bumper brackets
Mk1 Golf Diesel starter motor
1200 rear tin (between pulley and rear valance) Spoken for by Cosyclassics
black faced KPH clocks for bay window bus in plastic dash fascia
2x sets of beetle pedal tins
7x beetle under-rear seat plastic trim panels 2x Spoken for by Ross, 5 left
2x winder mechanisms
mk3 Polo starter motor
Seat Cordoba starter motor (suit '90s Polo too)
3x beetle drum brake spindles & backing plates
'70s beetle steering wheel
late '60s beetle steering wheel with half circle horn ring spoken for by rocky
pair of new handbrake cables Spoken for by Ross
various '70s bug side trim pieces
alarm/central locking kit (for 2-door car) Spoken for by Ross
bay & 1303 window washer bottles 1303 bottle Spoken for by Ross, bay bottle still available
1600 beetle exhaust, used (ERNST, Germany)
standard 1303 front springs Spoken for by Ross
2x doghouse fanshrouds Spoken for by Britt/Cosyclassics
2x 1200 single port cylinder head tins
2x twin port heads, uncracked but suitable only as rebuild candidates
late '60s Deluxe RHD dash panel cut from beetle
4x beetle under-seat heater ducts 2x Spoken for by Ross, 2x still available
4x "elephant trunk" heater ducts, 1x plastic, 3x steel 2x Spoken for by Ross, 2x still available
2x fuel filler necks between filler cap and tank
1300 twin port manifold, three piece
early bay grey faced KPH clocks, no plastic fascia
2x plastic-chrome late bug/bay headlamp bezels
2x '60s oval lamp reflectors
various '60s oval/tombstone/elephants foot lamp parts/lenses bulbholders etc
and other parts in the photos below. I'll do my best to itemise them all but if there's something you spot let me know
Trev, I'll take these off you...
... and whatever tinware you managed to rummage out for me too.
Thanks!
4x small rat-look suitcases Spoken for by Brendan O'Brien
1600 exhaust spoken for by rocky , 1303 springs Spoken for by Ross
window guides, decklid springs, '70s bonnet latch inner part
genuine VW bay window sliding door window seal. one piece window, no opening quarterlight, also does bay rear window in hatch (left one in the pic), don't know what the right one is, maybe bug windscreen/rear screen? both new, no chrome trim groove
bay window bulkhead and bellypan
4 vent decklid
1200 cyl head tins
doghouse fan shroudsSpoken for by Britt/Cosyclassics
beetle glass (some Audi/Derby mixed in there too)
LHS black basketweave seat, 2x black doorcards and 1x RHS red door card in background
15" tyres, all with good tread:
blade bumpers 3x front, 2x rear one pair spoken for by Podsyb, 3x still available
14" whitewall flaps, dirty but otherwise perfect spoken for by Jon White
14" redbands, 2 damaged, other 2 perfect
2x beetle patterned sloping lenses, 1x US spec clear lens, 1x "Bosch" script lens hanging onto the Bosch one for my oval
RHD glovebox lids 1x lid spoken for by Bug Eireann, 1x still available, speedo trim rings, early/late '70s beetle ashtrays, bay ashtray spoken for by krissovo, rear view mirrors, beetle switches
heater controls, LHD dash grilles, 1x RHD dash grille, "sporty" ;) pedal covers, 12V socket and 2x fag lighters, footwell vents 1x RHS vent spoken for by Brian R
brake/chassis parts plus 3-gauge pod from Porsche 924 (sexy brown!), bay rear hinge cover
fuel filler flap, release cable/handle, shift coupler inspection cover, fuel level sender, heater duct junctions
chrome trim crescent vent, yellow crescent vent, 1x wing trim, shift gate, decklid standoffs, steering box inspection covers
8x horn grilles, 5x accelerator pedals, bonnet hinge & spring 1x pedal Spoken for by Deckie, 4x still available
various grab handles, "T" decklid handle, decklid hinge brackets
2x beetle LHS door lock mechanisms, pair bay front door lock mechs, '70s bonnet latch/handle, passenger assist straps 2x straps spoken for by Bug Eireann, decklid latches (1 bolt, 3 bolt), door striker plates, fuel pump and pushrod
chrome interior door handle assemblies, black ones, odd extra parts for above, window winders black pair of winders spoken for by Bug Eireann, dome light
oil filler, 2x bowden tubes, oil pressure sender, single pole, Spoken for by Krissovo "Hoover bit" spoken for by Deckie, thermostat brackets, rocker covers, rocker shaft assemblies, fan shroud flaps, Spoken for by Britt/Cosyclassics gearbox mounts, type3 oil cooler, fuel pump, heat riser tins Spoken for by Cosyclassics
4x small VDO gauges clock & volts Spoken for by Ross, other two plus panel Spoken for by Krissovo
stainless steel anti-roll bar clamps
grey KPH bay clocks
under-engine tins, two of the flat pieces are spoken for by ross/Liam Beetlebug, the rest spoken for by Cosyclassics
PHEW!! anything I missed or anything you want just ask
the clock and volt meter are spoken for but the oil pressure and oil temp gauges and the panel they're in are still available. I have a single post oil pressure sender and "T" adapter to put the oil pressure switch back into too if you like, €30 the lot
6V starter motor (any idea of condition?)
1x good RHS quarterlight (maybe reserved for Deckie?) Yes please
a clean accelator pedal
Is there an oil pressure sender hidden in one of the last pics?
The bottom left headlight lens is for your oval ....Any chrome rims to suit these or sloping headlights
do ya know if the polo starter is the same as a mk2 golf 1300 starter (i would imagine it is) how much? also how much for the basket weave seat and door cards
Deckie, I tested the starter on 12V and it appears to work alright.
RHS quarterlight
ordinary oil pressure switch or sender for a gauge? Krissovo has reserved one sender for a guage but I think there's another if that's what you're after. If it's just a switch for the idiot light then I have a couple, you can have all of them, one is bound to work.
I'll pick the best accelerator pedal for you
have some sloping headlamp rings, from memory the conditions arn't hectic. I'll check for you.
so, for the starter, quarterlight, oil pressure switches (or sender for gauge), accelerator pedal how does €50 sound? If I have a good headlamp ring you can have it in the deal.
@ Walshe, it depends on whether the starter is on the gearbox or the engine side of the flywheel. The Polo/Cordoba starters are both on the engine side, near the firewall (they're interchangeable by the way). Check your application and let me know.
For the LHS basketweave seat and the pair of black door cards, €50 if you want a starter too, I'll throw it in the deal.
re lens, if you do have one Graham, do you fancy letting it go? Pick something you need to swap for it, might have some parts to suit your Passat, depending on your needs ;)
