so who fancies a go at building a car to a specification for a bit of tight and competitive drag racing ?
a rough specification
eligible cars- beetle ,ghia,type3Unmodified floor pan with beam or McPhersonstruts , with full working brakes .
Unmodified shell , doors, boot and bonnet can be lightened/fiberglass , extra bracing, stiffening,cage allowed . seat belt or harness must be fitted . windscreen must beoriginal glass. Other windows can be replaced with plastics .
Tyres / wheels no restriction .
Transmission swingaxle or irs no restriction to ratio’s .
Engine max capacity1641cc
Max Bore 87mm max stroke 69mm
Cylinder heads, max valve size 32mm exhaust, 35.5 mm inlet these are standard size.
Heads can be modified in anyway so long as the valve size remains stock.
No restrictions to the following
Crankshaft , conrods, flywheel, clutch, camshaft, valve rockers.
No restrictions to exhaust system. or carburettors .
these cars would run in the 18.9 to 16.9 second range .
please discuss ..
please discuss ..
