[Wanted: Parts] trailing arm for a balljpint beam
chewy356
220
88
Meath (Ashbourne direction)
need one trailing arm for ballpoint frontend, doesn't matter which one or condition. just need to hold torsion leaves for machining.
meath or north Dublin would be great an I will pick up.
thanks for reading.
Tim
2,951
243
Midlands
www.boards.ie
thanks for reading.
Any chance of a picture of that old thumper:D
Cant help with the trailing arm tho.
378
Hey Chewy..
The best way to drill them is on a milling machine or a proper drill press. As they are hardened steel, the leaves will try and move when the drill hits them. You need to drill them SLOWLY, with a centre drill and then a drill with the correct angle to secure the grub screw.
It is a 15 minute job with the right gear. If you get them up to me i will drill them out for you.
Cheers, Paul.
chewy356
220
88
cheers for the offer Paul. There is a local lad here who does bits for me, he has a a full on machine shop out the back of his house with 30ft long lathes and all sorts and I get him to do a few bits for me. Caddy posted pics a while back of doing the machining of the dimple and he used an old trailing arm to hold the spring plates tight, and then drilled through the grub screw hole - seemed like a good plan, so was going to give my guy the old trailing arm and let him use it the same way.
Tim, I don't seem to have a decent picture, at least I cannot find one on this computer.
Tim
2,951
243
Midlands
www.boards.ie
Picture is great, the old AJ.. brings back many memories. I had a good few of the old singles myself. used to do a lot of work on them back in the day. Not too many around now though.
Nothing like the sound of a single cylinder thumper......
Nice one:D
AntiGrav
145
Wicklow
My brother back in New Zealand used to have a Matchless G80. Amazing machine. 500cc single wasn't it? He still has a Norton Electra packed in grease in his garage. There were some great bikes in the neigbourhood - Norton , AJS, Indian, Triumph. When I hear an old British bike, it is like listening to music :D
