If I was dropping a late bay I'd be looking at these:
http://transporterhaus.com/index.php?option=com_content&task=view&id=71&Itemid=174
not cheap but no increase in track and they're quality kit.
I'm torn between these and a red 9 coil kit. Both are similar price. I want to keep my suspension so don't want to use adjusters.
Just thought I'd ask here first in case someone had spindles sitting on a shelf. I also don't fancy having to swap my stock spindles in case I ever want to return van to as it was when in service.
I have reservations about the EZ Rider kit as it puts a heavy load on the mounts which weren't designed for that purpose. Most other people have no issues with that and I haven't seen evidence to prove my fears. I think that Justin had that kit and had no issues. My concern is that some Irish roads put stresses on suspension that users in the Netherlands and most of the UK don't have to worry about and so they may not have run in to issues that an Irish user may eventually experience.
This post says that you have to cut the bump stop arms off to fit the EZ Rider kit which makes the installation more difficult to reverse:
http://www.volkstorque.co.uk/vt/mec...4595-cutting-bump-stop-arms-fit-red9-kit.html
Maybe someone here can sell you an old set of spindles that'd work out cheaper than the core charge if you went for the Transporterhaus kit?
If you drop your bus your off-road camping options will be reduced a little - might not be an issue for you but worth considering.
I did consider spindles, but as they're fixed at 3.5" drop I would have had to be pretty confident that the drop was going to work for me. The only way to raise it back an inch would be to fit an adjuster/adjustable beam.
I was very tempted by the Transporterhaus spindles because I was happier with the reversability of it and also because my balljoints are getting to the point where they need to be replaced and it'd be partly money that I'd be spending anyway. I also think that my bus looks a bit high at the front but its more or less the correct original height.
One of the things that put me off the 3.5" drop is the pic of the white early bay on this page:
That looks a little lower than I'd see as being completely practical for me. I'd like to drop the bus by max 2 inches but I don't want to rely on welded adjusters. I don't want to narrow the track and being a tightwad, I don't really want to have to change my nearly new OE sized Verdesteins. There's no easy, economic solution to this one.
TBH, they look a good bit lower than a spindle drop alone.
Ive got adjusters on 2 buses dropped about 3 inches and the ride isnt realy much different to the standard ones.your can take one out for a spin some thme if you want to see for yourself.
