So I have some stuff to go ,firstly a have a very good set of Karmann Ghia high back seats which came out of my 1969 there red in colour possibly need some padding but little else pics if needed ,250 ono
Now the beast -a 2.1 upright aircooled engine ,beautiful motor ,all tinware sand blasted ,filled smothed and etch primed -and 2k top coat matt red paint ,this is one of those engines you read about in Ultra and Volksworld -and @ 2k is a fraction of the price it would cost to build and I'm sure a smaller engine went for alot more in the last few months -
it was built by Laurie Petty.only has about 1000 miles ago so hardly ran in , crankcases-machined for 94mm barrels.,with long stroke crank=2110cc ,mild cam.041 heads,uprated oil pump+external filter.
solid pushrods.,009 distributer,petronix ignition+bosch coil,deep sump,lightened 8dowel flywheel,brand new 75amp alternator ,big bore,ceramic coated exhaust system.
genuine weber idf 40
-chokes machined to same as44s.inc linkages+filters.
recently dynoed at 93 bhp.+compression tested.recent oil,filter+plugs so the bad bit offer around 2k
Fire away with the Questions ??
