[Wanted: Parts] Beetle Rear Split Roof Section
riggsi
2,632
69
Trev are you allowed to drive with roof sections hanging out of the boot on L plates ?
How the fook did you make it home with out getting pulled.
1,812
there is a minor sub-section to a local by-law in appendix G of the Irish Statute Book that says that if they day has a "Y" in it, then yes, persons driving semi-antique Japanese family saloons with their wife's "L" plate in the window are legally entitled to carry oversize sections of rusty scrap hanging precariously from the rear luggage compartment of aforementioned semi-antique Japanese family saloon.
Those were the days before the Passat. If I had have tried the same stunt in that they would have thrown the book at me. It's only a semi-antique German family station wagon. Close one...
Good to know i'd be covered under that law so with the civic!
loadsabuses
1,455
28
kerry
No I'm looking for steel ...any luck
Thanks buggyboyshane but I want a split
Thanks again
coluld you not modifiy the oval section and turn it into a split . i know the oval window is bigger than a split but it would still look the part and be alot cheaper than buying a split rear roof section . just an idea .
oldspeedvws
1,269
115
Carrigaline, Co Cork
www.oldspeedvws.com
Assuming you can find an oval clip you could use a weld in section as loadsabuses suggests: http://www.thesamba.com/vw/classifieds/detail.php?id=216065
Read the ad carefully as the glass might need to be cut from the oval window one...
