[For Sale: Parts] 2 sets of running boards
Donnie
Active member
July 23, 2014
30
Ardee
As above. 2 sets of running boards for sale. one set with wide trim the other with the narrow trim. solid and in good condition and should look mint with a bit of a clean. 40e ono per set
Donnie
Active member
July 23, 2014
30
Ardee
will put your name on them. do you want pics of them. will check them tonight to make sure they are ok.
Donnie
Active member
July 23, 2014
30
Ardee
Wide set in good nick. surface rust on underside but solid.. where abouts are you located riggsi
Donnie
Active member
July 23, 2014
30
Ardee
closest i would be is dundalk these days. my location on here is a bit outdated. i could leave them with someone or could meet there
Donnie
Active member
July 23, 2014
30
Ardee
thanks stump. sounds good. should be down in dundalk some day next week. will let you know nearer the time
LWR75H
68
I would be interested in the other set if in good nick and if Stump would be so nice :) to drop them to Riggsi too so I can pick them up from his place.
Donnie
Active member
July 23, 2014
30
Ardee
wide trim set sold. narrow set available. split right at the edge where they bolt to the body but enough to stretch and not be noticeable when fitted. 30euro
