hi everyone.
i'm thinking of selling the complete engine from my beetle.
dont have all the details of it to hand,but il try remember-
it was built by Laurie Petty.only has abut 1000 miles since build.
cant rem the exact crankcases-machined for 94mm barrels.
with long stroke crank=2110cc.
mild cam-cant rem.the make.
041 heads
total seal rings
uprated oil pump+external filter.
solid pushrods.
009 distributer,petronix ignition+bosch coil
deep sump.
kennedy clutch
big bore,ceramic coated exhaust system.
inc.all tin-wear-could do with a coat of paint.+altenator.
genuine weber idf 41-chokes machined to same as44s.inc linkages+filters.
recently dynoed at 93 bhp.+compression tested.recent oil,filter+plugs.
some spares too.
i have the complete details written down at home,if anyones interested.
its still fitted to the car-so you can test it if u like-runs perfectly usually,tho it is smokey on start up sometimes-mabey coz i dont use it regularly,or mabey needs valve seals or something? also starts to run badly sometimes-seems to be after taking a corner/junction hard. i couldn't figure this out,but think mabey its a float sticking in d carb??
ring 087 3147920 if interested.
was thinking about 1300 euros.
need to sell in the next couple of weeks,to pay for subaru turbo engine!! can deliver anywhere in ireland
041 heads
total seal rings
solid pushrods.
deep sump.
kennedy clutch
some spares too.
