1302/3 seat guide rail wanted
i'm looking for a seat guide rail for a late notch back think it is the same as the 1302/1303 its the c shaped guide that is mounted to the floorpan next to the heater channel.anyone got a scrap floorpan?
Sh1t, put one in a skip today, and its right at the bottom, Im away at 6am and the skips being collected at 9!!!
I think it was pretty rotten anyway! If its the same as a 1302, will it not be the same as some 70's 1300's with the big block thats welded to the pan to guide the front of the seat?
2,687
Martin Murray has them as far as I know. I think the 1302 should have the 2 runners as opposed to the later traingular 3 point seat mounting. Give Martin a call 062 76177
2,308
I should have a "C" shaped runner if you're still in need Colm. I'll check the donor beetles later on :)
cheers lads was looking at the 72 square which has the c shaped runners and asuming it was the same as the 71 notch but on closer inspection last night it is totaly different so i will have to find a scrap 71 pan or make something up.*
