1964 Beetle.
whatucolm
650
101
Ended up ordering a set of OBX racing throttle bodies. They are made in America.Not the best quality,but the only ones I could find the bolt directly to the Subaru heads.They normally cost about $900.I got them for $500,plus postage and import duty,so I thought I'd take a chance on them.20251114_213006.jpg
Reactions: gerryjunior
whatucolm
650
101
Also bought a load of stainless steel to try and make an exhaust.I have three exhaust here,but the ground clearance is not great with any of them.Just trying to figure out what might work at the moment.Have a couple of ideas sketched out.20251114_211454.jpg
Reactions: trev
whatucolm
650
101
Nice progress!! The ITBs will be cool. Do they come with ECU and loom etc? Or what are you going to use for management?
Thanks Trev.They don't come with ECU or loom.I will have to get an aftermarket ecu.Link make mappable ecu's that will plug into the loom I have,but I will have to find out if that could be made to work with this engine.Most of the wiring for the main sensors,injectors,and alternator look the exact same,but they're is one less cam sensor.Have a bit of figuring out to do there yet tbh.
Reactions: trev
whatucolm
650
101
Bought a pillar drill at garage equipment. ie in Dublin on Saturday Couldn't believe they were only €200 Inc vat.Some great deals up there.
Drilled a big fekin hole in the intake with it,for the air filter.Surprisingly,it worked,and no animals were killed or harmed.The original intake was at the bottom of the manifold.20251122_182832.jpg
Reactions: trev and drifterex
drifterex
626
219
Waterford, Éire
Drilled a big fekin hole in the intake with it,for the air filter.Surprisingly,it worked,and no animals were killed or harmed.The original intake was at the bottom of the manifold.View attachment 400206
Seems a good piece of kit for good value. Loving the look of the engine. You gonna colour code the top of the air cleaner too?
Reactions: whatucolm
whatucolm
650
101
Thanks👍.It crossed my mind alright..not fully sure what to do yet to be honest.Not really happy with the look of it yet.The red filter element looks too weird to me,but couldn't find a black one.
