Wanted: AMG Alloys
Mr Browne
4,591
6
Louth
...and a partridge in a pear tree
you are just thick coz i don't want any of your overpriced and tacky porsche alloys :aggressive: :ROFLMAO:
as far as i can see the amg alloys just bolt straight on (which is always handy with wheels) and they look great
Porsche alloys just bolt straight on too...
(if you've already changed your drums/discs, use adapters, etc...la la la... :D)
2,294
as far as I know (which mightn't be as far as you ;) ) the AMG wheels intended for Mercs need their lug holes drilled out to 14mm (they're 12mm stock) and you might need longer studs/bolts on your T3 hubs.
Just a heads up in case you thought it was a true "bolt-on" fix :)
george
1,894
www.gacurley.com
Thanks dude – I’ve looked into this and according to http://www.brick-yard.co.uk/VehicleSpecific/T3/info/mods/alloys/altwhls.htm - some Mercs were 12mm and some were 14mm – so yeah – ideally I’d prefer 14mm – keep it truly bolt on.
drilling them out from 12mm to 14mm is easy once the centre bore is right
he already has longer studs on it!
P.S. i think i need to change my avatar!
