[For Sale: Car] T25 single cab project
T25 pick up
1.6d
apart from the bed and a hole below the lower front grill this is a very solid bus
engine is running but I am including a 95 golf tdi in the sale with a good 1.9 tdi engine.
I have fitted a new clutch slave cylinder,front brake flexy hoses and pads and a new front grill.
I was planning on fitting the tdi and giving it a respray but I havent got time for it.
€950 ono
2,096
It killed me to scrap a good Tdi but there were no takers at the time
unfortunately it was the "wrong" TDI for type25 conversion or otherwise due to the electronic controlled injector pump.
However, I've found out that the gearboxes have a nice low final drive giving really good fuel economy and they're the "cable change" type that will suit my Passat. All the other mk3s (except the GTI) came with a "rod shift" box. If I can find one for handy enough money I was going to put it into it as part of an austerity drive experiment ;)
SteveR
1,972
8
Knocklyon, Dublin
i could be wrong but as far as i know the 8v gti had a rod shift and the 16v had a cable change.
2,096
ah right, that's probably true. The VR6 had cable change too. No matter, it's just the TDI cable change box I'm after :)
He said most of the bits are already claimed....but the body is still all there, just no engine or running gear. :(
Gonna give him another call in the morning. ;)
