[Wanted: Parts] T25 2l aircooled fuel pump
andrew
191
37
kildare
Hi all
i am looking for a fuel pump for T25 2l if anyone has one or the details to change to electric pump
Andrew
lauragorf
New member
July 22, 2021
You shouldn't lose power on that fuel. If the fuel is too weak, the engine will start destroying with time. You can see in the manual of the car what fuel is good for your car. Or you can also visit cararac.com. There you can find all the information about fuel for your car. You can even find what fuel consumption you should have. If you have more fuel consumption, that means that something is not right in your car. This is how I understood that there is a crack in the gasoline tank of my car. Luckily I noticed that there is something wrong.
1,755
I had a facet fuel pump in my Bay van when it was aircooled and petrol engined. It just came on with the ignition, you could hear it ticking away quietly. It was fairly low pressure, the float valves controlled the amount of fuel into the carbs.
I bought a different fuel pump in later years for one of my diesel cars and it was like a power hose! You'd need a pressure regulator if running it on a carb engine.
Look up the Facet "cube" style pumps. That's what I had.
