[Wanted: Car] Quarter light Inner frames
Tim
2,957
245
Midlands
www.boards.ie
Still looking for quarter light inner door frames. The frames that fit into the door, and then the quarter light frame and glass is fixed to. If you have any half decent, I,d be interested.
Tim
littleredbeetle
143
cork
Is it just the frames you want or do you need the glass? Much easier to post the frames on their own, however to put in the glass you must get a special revit. However you could use a small bolt but it wouldnt look right.
Tim
2,957
245
Midlands
www.boards.ie
Its the frame that goes into the door first. The frame that is attached to the glass with a rubber gasket is attached to the inner frame by the rivet.
