[Wanted: Car] Mk1 golf
kongomush
*****youlater
2,586
22
Deaglan on here is selling his Campaign GTI
Updated Add, January 2012
It needs a good home.
1983 Golf GTI 1.8 Campaign, Diamond Silver
No Tax or NCT (Last NCT expired October 2010)
Interior is immaculate, as you can see.
Genuine EW chassis, Original DX engine with 116k miles.
Was originally UK reg A133CRR, now 83-DL-1667
Its all very standard, down to the 5 original Pirelli wheels, complete with 4 genuine centre caps (yes, with the raised Pirelli lettering)
I bought it from UK a few years ago and did lots of work to it.
New clutch
New crank seal (engine oil had leaked onto clutch)
New sump gasket & gear oil
New wishbones
New balljoints (twice !)
New Shocks (front & rear)
New springs (front & rear)
New topmounts (front & rear)
New bumpstops
New ARB bushes front & rear (genuine VAG)
New rear ARB outer clips
New discs & pads
New sunroof seal (genuine VAG)
New ignition switch
New track rods & ends.
New expansion tank, cap & level sender.
I used it as a daily driver for a while, but got itchy feet and garaged it.
Problems -
1. Front fog lights dont work.
2. Needs rear wiper motor (got a replacement but it was faulty also)
3. Flashing oil pressure light in dash - Engine has good oil pressure, suspect internal problem in dash electronics.
Other things that spring to mind are :
-Sunroof needs height adjusting as it scrapes very slightly when slid open
-small crack on outside of driver-side headlight glass (passed last NCT)
Comes with lots of parts that I never got around to replacing :
New rear brake drums
New rear brake shoes & fitting kit
New water pump, thermostat & thermostat housing (with new O-ring)
New sensors for oil pressure (high & low) and water temperature
New sparkplugs
New dust/dirt guards for front discs
One new plastic wheelarch GTI trim (i think its front left, will check)
And also comes with some parts that came with it when I bought it:
-Wiper mechanism
-Matching lock set (Ignition, Doors & boot) - Currently all are different keys
-Used heater fan (came with car, condition unknown)
-original plastic air intake pipe (has pipercross straight aluminium pipe fitted)
Also comes with 4 springs. I think about 20mm higher than GTI so maybe standard Mk1 Golf springs ? I fitted them and realised they were too high. Probably around 1000 miles on them.
Location is Letterkenny, Co. Donegal.
Price is 3500 ono
More pics HERE , and I can email high-res versions if needed.
Cheers.
Declan
