[Wanted: Parts] Knurled knob wanted :)
2,401
36
I'm looking for one of the little metal gizmos that screws onto a thread and holds the wiring cover onto the bulkhead. Anyone got a spare?
2,309
I could make you one in work in aluminium or brass pretty quickly, easily and for free. Let me know the thread size or get me a picture of what it should look like and I'll knock one up. You have two weeks though, I get my hols on the 15th :)
2,401
36
Cheers Trev - I appreciate it. It might be more work than its worth but I'll post a pic tonight and you can see what you think then.
oldspeedvws
1,269
115
Carrigaline, Co Cork
www.oldspeedvws.com
This?
2,309
if it's that ^^^^ I think I have a couple spare in the garage, they come on the back of VDO gauges. M5 I think. It would be a 10 minute job to make one. It would have a diamond knurled pattern though...
2,401
36
That's the one Johan - thanks.
Trev - I need it to match the existing one on the other side of the wiring cover. The VDO ones are shorter I think - these ones are 14mm long and are M6 threaded internally
2,309
if you want two diamond knurled ones measure up the one you have, let me know and I'll make up a matching pair.
2,401
36
You're a gent Trev and I'll make a contribution to your beer fund when I see you at Monard.
Its 14mm long, 12mm diameter with a slot at the top which is 2mm wide and 2mm deep. If you're feeling particularly generous with your time, the bore at the slot has a slight rebate (you can see it in Johan's pic above)
Edit: Just to keep the numbers all in the same place - its an M6 thread.
2,309
leave it with me. it won't cost me anything so it won't cost you anything. Throw a few coppers in the next charity box you see :)
