[Wanted: Parts] Beetle Door Frames - Wanted
knk
3,428
3
Dublin, Ireland
Guys...I'm in need of both LH & RH door window frames from a Beetle as soon as possible.
Just need the door frame that goes around the window, not the whole door. So if anyone has any crappy doors that are completely rusted on the cills then I'll happily take them off you for a few pound! ;)
Tks!
1,700
there's a left door left over here from the resto of Paul's beetle, it's been repaired at the bottom but is rusty again. He's away in Oz at the moment but it's basically scrap so I reckon if you want it he'd be happy for you to have it. If you don't take it, it's going to be scrapped when the crusher takes away my scrap metal.
Rocky
2,370
141
North Wexford
I've a right door (& a left if Pauls is not available), doors are shot but frames should be ok, i'll check in the morning.
knk
3,428
3
Dublin, Ireland
Cheers guys...here's a pic of what I need. I'm sure both doors, even rusty will have good frames on them. Rocky, if you have both I can pick them up from you, save having to do 2 trips. If you don't fine, I'll take a spin down to you Trev too and bring that other shelf and the same time.
Rocky
2,370
141
North Wexford
Left one doesn't look great, the right one should be ok ...
Rocky
2,370
141
North Wexford
John, I can cut the window frame off & bring them with me to work, if they're no good give Liam a shout, he's only up the road from you.
I should have two aswell if all else fails they're goin for scrap once i take the one piece windows out
knk
3,428
3
Dublin, Ireland
Wow...so many options! :)
Rocky, they look ok for what I want them for. If you can cut them off and bring to work that would be great. Just let me know when you have them up and i'll drop over to you.
Thanks Liam & Duts, I'll keep you both in mind if the ones Rocky has aren't enough! ;)
Rocky
2,370
141
North Wexford
Too lazy now to go out and cut them .... i'll do it tomorrow evening if i get home reasonably early so should have them Tues/Wed ... i'll be passing thru newlands cross on wed at around lunch time if that helps.
knk
3,428
3
Dublin, Ireland
Wednesdays perfect...thanks!
