[Wanted: Parts] Ball joint Narrowed Beam
387
matara, i have a beam complete with disc brakes, of a gt beetle for sale.
if you want , i can narrow it for you ,and weld in the adjusters.
let me know if youre interested.
stump.
387
well steve, the beam complete, disc to disc is 250 euro. your mad spending a load of cash on the beetle if youre going back to oz!!!!!!!!!!!!!
matara
403
Sydney, Australia
Your probably right, but this was my first beetle and I never really got to drive it after I restored it. For example its had the same tank of petrol in it for the last 7 years, as it only got used for a couple of weeks a year when I was back from Oz. I've not been back in 3 years so the brakes need re-doing. I might take your advice and just put some new wheel cylinders in and drive it!
Out of interest what would it be to narrow and weld in adjusters to that beam?
Cheers
Steve
387
bug1.jpgwell stevo...
heres one i did for myself. its narrowed by 6 inches. 3 inch of each side. its probably a bit narrow to be honest. i think 4 inch is more realistic. the turning circle is not nearly reduced as much.
theres 2 days work in doing a beam properly.
cutting out the centre section and welding in adjusters , cutting 2 inches out of each side and rewelding, shortening the leaves and redrilling them .
( i presume your putting the leaves back in and not running through rods.)
shortening steering arms.
youll probably want to push out the old ball joints and press in lowered ones too.
i presume your gonna run lowered spindles aswell.
id have to charge you 250 euro
count in the cost of two lowered shocks, caster shims, reverse tie rod kit , new bearings and brakes, the cost doesent be long creeping up.
plus the whole thing needs to be set for camber, and then tracked aswell. thats another 50 euro.
if your going this far, why not look at air ride? im working on my own set up at the moment. should be ready shortly.
stump.
post a picture of your bug.
