[For Sale: Parts] 1600 engine for sale
caddy
724
Armagh
bugbitz.com
just finished a 1600 twin port beetle/bus engine.
align bored case , new bearings , seals and gaskets, honed cylinders with new rings,
good vw heads with long reach plugs, 200mm flywheel.
bench tested and running sweet.
long block only @ £499stg.
call me 02837548072 for more info.
Bugnut
1,141
21
Hi Dave
Would you take a case as a trade in /px ?
AS41 case need a bore - 1st time bore .
caddy
724
Armagh
bugbitz.com
Hi Dave
in answer to your question , yes i would take a case as a trade in.
i dont pay much for them though !!
if you breakdown the build costs , there are £150 new parts, £50 machine work , £200 for 12 hours building and testing ,
that only leaves only £99 for a case, crank, pistons , barrels , heads , cam , and valve train, which are all good used items still within factory spec.
so as you can see im almost giving the engine away ..
caddy
724
Armagh
bugbitz.com
i now have another 1600 twin port for a beetle or split van , dosen't have the mounting points for a bay.
align bored case new bearings seals and gaskets , good vw heads with new valves , refaced 200mm flywheel, low mileage pistons and barrels fitted.
bench tested .
long block only £499 stg.
also for sale.--
a new set of mahle 1300 pistons and barrels no rings. 150euro.
a near new 69mm vw crank with 200mm flywheel , from an engine that has only been bench run , customer then decided to change to a stroker 200euro.
brand new vw as41 crankcase £499..
brand new cb performance 82mm crank £350
used dellorto drla 40 carbs refurbished ,mint condition £340
caddy
724
Armagh
bugbitz.com
also a reconditioned bottom end AB code case case align bored , new bearings , end float set,180mm flywheel . ready for piston/ barrels /heads to be fitted. £250stg or 300euro.
i have a selection of align bored cases ready to build on from £125 or 150euro
or i can align bore your case if its clean and measuring ok for £75 or 90euro
tonyvw
2,618
90
cork city
irish vintage
wanted 1600 twin-carb air cooled engine with gearbox [preferably 5-speed]
must be complete and running well would take complete car
ph 087-2205720
CHECK THIS OUT
