Wanted Gearbox Coupling Nut
Dan smasheen
Member
April 19, 2008
20
Walkinstown, Dublin
6,333
What Dustpuppy said. It's much easier to use a 13mm bolt head instead of the 10mm square grub screw which is OG. I have the T-handle 10mm square wrench to take these out but it's a Royal Bitch to do if you don't have one.
Dan smasheen
Member
April 19, 2008
20
Walkinstown, Dublin
That's what's left of the bolt.
Hi Guys,
This is the bolt and I don't really know much about tapping the yoke or what OG means. Previous picture of the nut was in happier times.
I tried the tapping bit and my missus went apeshit. I must be doing it wrong. Flooded the joint.
Where do I get the tapping gear and what's the go?
Cheers for the tips.
http://i473.photobucket.com/albums/rr93/Dan_Smasheen/Nut.jpg
http://i473.photobucket.com/albums/rr93/Dan_Smasheen/Tap.jpg
M
mango
i picked up a 091 box last week with the coupling still attatched , i`ve no use for the coupler piece so give us an address and i`ll stick it in the post for you
the screw in the picture above isn`t the OriGinal part
