Bargain ,that gearbox is perfect for diesel engine also ,very same ratio just swap on diesel bell housing ,cut 12mm off end of spigot shaft and yer set ,these boxes are making twice that price in UK
Yes you can fit this engine to your diesel gear box, but you will have to change your bell housing and I/P shaft, the ratios should be ok depending on you gear box.
