[For Sale: Parts] T25 body cuts - doors - springs etc
Bugnut
1,146
25
Hi All.
I have a T25 that has to go.
The chassis rails are way beyond repair but the body is in surprisingly solid condition - I bought it as a donor but didn't need nearly as much as I thought.
Come take it away or take a piece you need .
Front Doors 1 - 90% - €50 - the other will need a small patch welded on outer lower skin - 30mm square - €30 - all rubbers except for 1/4 light will need replacing.
Left hand sliding door - 90% - €100 - no holes cut
Rear Door - 70% - usual lower edge rust - can be saved - €50
Any other bits just ask.
***** NO LIGHTS AVAILABLE*******
Location - Meath
is it a panel van or caravelle/mini bus? if its an original caravelle/minibus with the stepped in (factory style) 'flat' rear windows' (rear of the sliding door) /middle panel ?...id have an interest... Was/is it diesel or petrol; I cud do with a RHD diesel dash loom -to fuse board.
