[Wanted: Parts] T2 Bus Engine Wanted
brianm
643
23
Tipp
Any late bay engines for sale? 2.0 Preferably. Anyone done a conversion and have one sitting around by any chance :telephone::thanks:
Hi, Have 1600 fully rebuilt, AS has 3 threaded holes under pulley for transporter crossbar. Case alignbored, new bearings, NOS VW German crankshaft, New big end bearings, barrels honed, new rings, heads rebuilt, new exhaust guides & valves, Faces & seats recut & reground, Compression all over 110PSI, Oil pressure >3 bar @ 2400 RPM. Refurbed original heat exchangers, newish standard exhaust box, Bosch Alternator, new fuel pump, refurbed bosch distributor, correct tinware. 215mm flywheel, have new clutch disc & pressure plate if needed. Give a call 0857827537. Regards, E
Reactions: brianm
...heres a disassembled one I saw on adverts; https://www.adverts.ie/parts-accesso...ngine/14913751
...looks to be a twin port from the pics -I spose you could argue it all there already blown apart n you can check heads for cracks, the pots for lips, crank still in it, for end float; etc- if you're replacing a 'blown up' one, might be a good prospect to make 'one good from the two...
...if its goin into a late bus, I have a spare t25 box that'd provide a bellhousing that could be bolted up etc for a 'diesel conversion' on the t2
