I picked this up earlier this week from a guy that bought it , tried it and put it back in the box, which is where it sat for a few years.
He only remembered he had it during a garage clear out, and as you can see it is practically brand new.
Originally I wanted a welder to provide me with a lower amperage than my current set up but the difference does not justify me having another welder , so here it is.
My current set up runs from 40-240 Amps - I had thought the 25 Amp startup would be easier to weld panels with but it is about the same as the plant I have.
This welder runs from 25- 150 Amps
It is loaded with gasless wire but can easily run with gas if you prefer - 2 hobby bottles of Argoshield and reg are included as is a new pack of 0.8 tips
Welds panels fine and will go up to 2mm welding pretty ok, but as for the stated 5mm - I dont think so, not welding well anyhow.
So if you want a little cheap mig to get you going , here you go !
I will swap/px for tan leather front seats, t25 bits, DA sander, cb radio(good one)
