[Wanted: Parts] Second hand T2 2000cc long shaft starter
Grogg
Member
February 19, 2010
12
Co. Clare
Hi all,
Have my 2000cc 1979 T2 starter going through a refurb but I am having an issue sourcing an armature, its for a long shaft starter. Any ideas in where I might get one or a second hand starter that I could take the armature from?
Appreciate any feedback.
Kind regards,
Greg
BLZEEDUB
143
tipperary
i done know what armature would suit a t2 2l starter; have you tried or looked at any of the early T25 aircooled starters, or the 'B2 passat' range?? I have had some 'luck' with rebuilding/refurbing a 'worked for previous owner; just not ffor me) dead diesel t25 starter; a working but surplus to anything I now own; a B2 Passat 1.6d starter was on the shelf ; bendix n housing n solenoid didn't seem interchangeable....long story short I used the armature on brush pack off the b2 starter in the T 25 starter, it was like 100% afterwards....
Edit; I remember initially weighing up the prospect (folly??) of bustin apart a perfectly working starter( for a car I no longer own) to revive a dead starter, for a car I now do; I read (on the starter body) nlooked up the part no's of each; the no's at the end didn't seem 'that far apart' - so I proceeded with the disassembly....
....might help you in your search if you intend on continuing on refurbing your starter...
magpie
156
16
Sligo
Hi Greg, Have long shaft starter (German Bosch) in running order. Give call 0857827537, Regards, E
2,437
An alternative is an adapter plate plus a golf tdi starter from circa late 90s early 00s. They're 2kw. You'd start a tractor with them!!
