Hi,
With new found enthusiasm for my engine build I'm putting this out to see if anyone has the parts I need knocking around or spare.
I'm looking for:
Engine case - Ideally cut and clearanced for big capacity barrels 90.5, 94s.
Barrels and pistons - Large capacity again.
82 mm crank
Cam - FK8 or something similar compatible with 1.4 rockers.
Cam followers - Do I need to look into lightweight or hi-po followers or do people use standard?
Flywheel - Lightened ideally
Clutch hardware
Heads and hardware - Valves, springs..
Merged exhaust
I figure these aren't typically the type of parts that people usually have lying around, but always worth a try.
What have you got??
Colin
I'm looking for:
82 mm crank
Clutch hardware
Merged exhaust
What have you got??
Colin
