Hey guys, anyone have a passenger side IRS arm going spare? Needed for an IRS conversion.
Also on the topic or irs, I am sure some of you guys have done an IRS conversion. I want to run pretty low, so was thinking that setting the toe and camber at the appropriate ride height should tell me where the pivot needs to be prior to welding, or am I mad? should I just weld up a jig to locate the way VW intended and live with a little camber due to running low (I don't think I will be going low enough to justify swapping arms across). I understand the risk of getting it wrong, but if it is easy to setup perfectly for a lower ride then would like to do that
Cheers
Chewy
Cheers
Chewy
