[For Sale: Parts] Esab Origo Tech Auto Darkening Welding Shield
Bugnut
1,146
25
Bought this before Christmas for the TIG welding course I am doing.
€118.50 €95.00 Product Code: 7570 The latest design in ADF helmet. The Origo-Tech is available in 2 striking colours, Yellow & Black, finished in a high gloss paint, which allows longevity of look and style. The helmet is equipped with a 9-13 variable shade ADF, which extensive field trials and tests have found the unit to be extremely efficient & reliable.
Lightweight, the helmet is designed from a very durable A801 material, which allows for position welding, with increased comfort and reduced fatigue to the welder.
Features & Benefits:
Head Gear
  • 4 Position Settings – This ensures the wearer has the perfect fit across the head area
  • Large Rear Adjustment Knob – This allows the wearer to adjust whilst wearing thick welding gauntlets
  • High Quality Sweat Band – This offers increased comfort to the wearer
  • Robust Nylon Construction – This strong material provides a firm foundation for the helmet shell, and is extremely durable
  • Rear Pivot Pad – This allows for the perfect head fit, and highly adaptable to all head shapes
Helmet
  • Full Face Protection – Offering protection to the face, chin, throat & head area, providing complete facial coverage from sparks ,heat and radiation
  • Flat Top Brow – This allows for easy put downs, and will help to reduce scratching of the outer lens
  • High Gloss Finish – With strong visual impact & styling the shell can also be easily wiped of dust and dirt
  • Extremely Reliable – The helmet functions on an extremely reliable ADF filter, which is always active, with no On/Off switch
  • Solar Cell Technology – The ADF uses solar cell technology which means there is no battery change needed.
  • Light Seal Cradle - The new Light Seal Cradle not only shuts out any Welding Arc Light, but it also introduces a Convex curve to the front spatter lens. This provides extra security and strength and a healthy air gap for the ADF.
Standards
  • CE Certified
  • ANSI Approved
Technical Data:
Viewing area 96 x 42 mm
Weight (ADF) 99g with inner protection lens
Total Weight Helmet – 525g
Open state shade 4
Closed state shade 9-13
Shade adjustment – External Potentiometer
Sensitivity adjustment – Internal Variable
Delay adjustment – Internal Variable
Switching time at –5ºC : 0.0008ms
Switching time at +25ºC : 0.0005ms
Switching time at +55ºC : 0.0002ms
Clearing time : 0.1 – 1.0s
UV / IR Protection : UV15 / IR14
Temperature Range : -5 / +55 Degrees C
TIG detection : >20amps
Energy supply – Solar Cells / No battery charge
It is brand new, literally been out of the box once.
The issue is that it only darkens at 20 amps so its a problem for me doing Tig from 5-10 amps as it does not darken at that level.
So I need a better one.
Grab a Bargain at €80.
Bugnut
1,146
25
Yes Brian its bang on - you really wouldn,t weld much with a Mig or Arc at less than 20 amps - probably wouldnt even get the stick to melt at a guess.
For almost every normal welding application you wouldn't even notice, were just practicing using the foot pedal control on a TIG plant on very thin stainless so would start to generate a weld puddle at 30-40 amps but reduce amps to allow greater detail in the weld and thats when the shield wont go dark.
For any car or home welding projects it would work well.
Ok, I'll take it then.
