Dellortos, fanshroud, T-bars, baja kit
1,710
I have a pair of Dellorto DRLA 36's, manifolds, linkage and doghouse early style fanshroud (the carbs won't with the "wide '70s shroud) collected up that I was going to fit to my bug but I don't think I'll ever get around to it.
€400ono the lot
a set of T-bars, replace your bumpers with these for the cool stripped-down cal-look... They're steel and painted black. Bought them from SSP a few years ago at the VolksWorld show. Suit a bug with early bumpers.
They're just shy of STG£40 new. I'm looking for €25
I also have a new-unused 7-piece baja kit. No pics at the moment (it's in the loft) €200
mac
problem there is I'll have to build a bigger engine -44's are a bit on the large size me thinks -is it possible to use smaller jets to restrict them??? I'm still on the carb learning curve and trying to get the right engine with the right parts to suit .
how big is your motor? you can choke them down, but compression and heads will determine a lot.
1,710
I can root it all out later on and get a pic.
The headlamps mount in the front wings, not the nosecone but the wings haven't been cut for headlamps, they still have the blank disk where the lamp would be.
