John, The heads I have are from a 2.0 CU, but if they are any use to you I can split, It turns out after a chat with caddy that my CU engine has end float, so it looks like breaking is the only way to go for me. Let me know If they are any good to you...
Hi Paul thanks for the offer of the CU heads at the moment i am still hoping to find a head from a GE code engine so that i only have to change the one head .if i fit the heads from a CU i will also have to fit the matching heat exchangers which pushes the cost up on an already stretched owner .
thanks again for the offer
