[For Sale: Parts] clearout of aircooled parts
1,710
I have no immediate need for this stuff so it's for the chop!
12V dynamo with wider "doghouse" fan attached
early '70s large oil bath air filter
rearmost "breastplate" tinware piece, 1x 1200, 1x 1300
small piece of tin that covers the bottom pulley nut SOLD to Rattyoval
1300 twin port inlet manifold, 3 pieces
crossbar from under the rear seat
pair of 1300 cylinder tins, upper
doghouse oil cooler manifold/bracket
dynamo stand
doghouse tin, the triangular one
doghouse oil cooler
the frontmost tinware piece, over the gearbox, with the outlet for the doghouse downpipe
1300 flywheel & clutch, probably worn out tbh
1300 pots and pistons that were weather seized, probably for the bin unless you want a challenge
1300 rockers, pushrods, rocker covers etc
stock camshaft from my old 1600 engine that I seized plus its gear. Not the "three rivet" kind.
I'll add more later as I find it.
all parts cheap to clear. Tell me what you want and I'll dream up a price. As an example: dynamo and fan: €15
can arrange postage/courier/parcel motel/eircooled express as required. At your expense, depending on method.
1,710
the trainline going right through Loughmoe makes it fierce handy to get my fleet around en masse ;)
cheers
1,710
which two pieces broz?
it's effectively these three pieces I have:
233850d1303938918-restoration-project-68-vw-beetle-o-_-_-o-copied-27th-april-2011-013.jpg
broz
479
97
glanmire
That's sweet, can you post Trev? Add to the bill and I'll PayPal u if its ok, parcel motel is good for me
