cal-look window seals and Kamei tunnel tray
I have a windscreen seal, rear screen seal and two rear side window seals, all new, all "cal-look" trimless style. Just checked the prices on VWHeritage site, they're around STG£20 each new plus postage. I must check to see if the rear screen seal is pre or post '71. The other seals will do any post '65 bug except the 1303 windscreen...
I'll take €60 for the lot. SOLD
Also an original Kamei tunnel tray, sits over the gearlever base and goes forward from there. I've opened up the hole for the gearlever to approx 2" x 2" to get it over my Hurst style trigger shifter and there's slight cracking to the left corner near the gearlever but it's only visible if you go looking for it. If you don't have a Hurst shifter in your bug I'll provide the black plastic base cover that would finish off the base of your shifter and hide the opened out hole in the tray.
€20 for this, nice original accessory to have in your bug. SOLD
oh yeah, I have a single 3 point beetle seat in black basketweave. I'll get a pic and pit it up here so you can see if it suits.
emmett, this is the single basketweave seat I have. It's a left seat. It's not quite perfect :(
€20 if you want it.
