I know most of these can be bought in the parts suppliers but I thought I'd see if I could turn up anything amongst the VW community first
I need the following: (all for late model 1976 beetle BTW)
1x 2-pin ATE brake caliper (late beetle)- 2x brake flexi hoses for disk brakes
- LHS interior sun visor in white
- shift rod coupler
- shift rod bush
- pair wiper blades
- LHS stock door mirrors
- windscreen rubber with groove for trim
- ignition switch "Plug" type
- ignition barrel & key (actually the entire 2-lever steering column head would save me a lot of hassle)
- clip-on bonnet seal
- stock style black plastic dash pad
- 2x inner door handles
- fuel filler cap (preferably locking)
- engine bay rubber seal
- rear seat cross bar (the bar that goes from one door pillar to the other, supporting the rear seat)
- 1x set of front wheel bearings
- 1x front wheel bearing grease seal
- pair of caster shims for lowered front beam
- 1x LHS stock spindle for disk brakes, ball joint
