[For Sale: Parts] 2276 engine (dam you trev )
wackerwacker
924
214
waterford
WP_20150214_017.jpgWP_20150214_016.jpgWP_20150214_014.jpgWP_20150214_013.jpgWP_20150214_011.jpgWP_20150214_010.jpgWP_20150214_009.jpgWP_20150214_008.jpg
the making for a 2276 type 1 engine 48idas old school mag etc,etc,
wackerwacker
924
214
waterford
engine past list
AS 41case cut for 94mm and cleared for 82mm crank
82mm crank
fk89 cam
H rods
heads are steve tim's stage 2 42x37mm
IDA 48s manifolds and linkage 44/43/40 vents
Vertex mag
taco and controller for a mag
1.4 rockers
oil cooler
spring pushrod tubes
30mm cb oil pump
deep sump
tin wear
power pulley
1 5/8" header and copper gaskets
fat boy exhaust
cb flywheel nut
lighted flywheel
kendy stage 2 clutch
94mm pistons AA stoker and mahle
94mm mahle pots
alloy bolt on rocker covers
it just need put together:p
58Panel-Youny
1,568
wicklow
Can't believe this bargain hasn't been snapped up... If only I had money for another engine build. Those carbs alone are prob worth around a grand!
wackerwacker
924
214
waterford
engine past list
AS 41 bus case cut for 94mm and cleared for 82mm crank 150 euro
82mm crank, flywheel, straight cut and new bearings 260 euro
fk89 cam 60 euros
H rods 200 euros
heads are steve tim's stage 2 42x37mm 575 euros
IDA 48s manifolds and linkage 44/43/40 vents 1150 euros
Vertex mag
taco and controller for a mag 450 euros
1.4 rockers 100 euros
oil cooler 40 euros
spring pushrod tubes 40 euros
30mm cb oil pump 50 euros
deep sump 60 euros
tin wear ?
power pulley
1 5/8" header and copper gaskets 150 euros
fat boy exhaust 80 euros
cb flywheel nut 35 euros
kendy stage 2 clutch 80 euros
94mm pistons AA stoker and mahle 94mm mahle pots 120 euros
alloy bolt on rocker covers 80 euro
:p
right girls and boys I will part this out
Dubman77
New member
February 28, 2015
United Kingdom
Hi, interested in a few bits - can you get me a price for the below bits posted to DA53QH England please?
deep sump 60 euros
I would have bought the lot if i had the spare cash!
best regards
Rich
wackerwacker
924
214
waterford
deep sump 60 euros
best regards
Rich
no problem just give me a few days:D
pm me your phone number and I will let you know
thanks ed
