[For Sale: Parts] 2110 CC Competition Engine
aircooledtechnology
SOLD - Coming soon 1775cc engine.
Newly Built 2110 Competition Engine
Brand new raised crankcase
Race Chromoly Crank with race bearings,
2411 Race Camshaft with strait cut gears. Cam dialled in,
Ultralight Lifters,
Race Con Rods,
Wiseco race pistons. Male Cylinders,
Dual lip Flywheel oil Seal,
Chromoly Lightweight Flywheel, Clutch optional , many possibilities,
SS Pushrod windage tubes, Chromoly cut to length pushrods,
High Ratio bolt up rocker assemblies, Finned vented valve covers,
Race 044 Heads by CB, Big Beef Manifolds required,
Twin Weber 44 s,
Serpentine Belt System,
CB Breather setup, Drilled & Tapped for external oil cooler/filter/stat. Gene Berg oil pump cover, 30 mm oil pump gears. Many possibilities.
Will Fit Beetle all, Type 3 all but change of tinware, T2 all, Karmann Ghia all, Buggy, Trike etc.
Will sell as long Block only or fully built upm as T1 T2 or T3 with or without external lube system.
If interested, please call us on 0872552578 .
aircooledtechnology
We do engines from 1600 stock to bigger competition engines like this one.
Approximate prices of our engines, all brand new:
- 1600cc Long Block €2995
- 1775cc Long Block (Currently being built, so it can be built to different specs. Using 044 Heads) €3995
- 2110cc Long Block (The engine of this ad, but in long block version) €4500
- 2110cc Fully Built (As seen on this ad, with Carbs) €6500
For any enquiry we can be contacted at aircooledtechnology@gmail.com and we will answer very quick. We may miss the messages on the forum.
Thanks!
