these are parts left over after I made one engine out of two recently. I was going to hang onto them as spares but it would just be more clutter being hoarded for a rainy day that will probably never come...
thermostat €40 (these are STG£70 from Heritage, believe it or not!)
crank pulley €15
type1 "doghouse" oil cooler plus manifold €30
1600 rocker assemblies plus rocker covers plus pushrods (not pictured) €30 the lot
twin port (i.e. 1300 or 1600) cylinder tins €20 the pair
1600 (large flange) 3-piece twin port inlet manifold €40 (carb not included)
1600 clutch (180mm from memory?) plenty of life left in it €40
55A internal regulator alternator plus pulley, backing plates, fan, strap and pedestal. Bar a bit of rejigging of wires under the back seat (beetle) to delete the voltage regulator, this is the complete conversion for a dynamo beetle or bus. The alternative is Chinese shite that doesn't work €120 I'll even throw in a new belt
doghouse fanshroud €25 alone or €40 with the extra doghouse tins
1600 bay moustache bar €15
SVDA distributor €40
some of the parts above (fan shroud, dog house tins, oil cooler, tinware) have a "first dibs" given to a member here. I'm just waiting for word back. If you're interested in them let me know and I'll let you know if he decides against them.
Discounts available for multiple purchases. No swaps, cash is king
Well... I'd consider a swap against an oval beetle steering column
crank pulley €15
