[For Sale: Parts] Weber 40 IDF carbs for an inline 4 engine
8,449
39
I have a set that I bought back when I was building my engine thinking they'd do the job but the linkages are set up in such a way that they interlock side by side so can't really be operated on either sides of the engine without some complicated modifications (or if you have a set of unserviceable carbs you might be able to rob the butterfly valve spindle off them and stick it in these which should allow you to run them on a vw engine). Anyone on here have a use for them? I'll let them go for €250.
Here they are...
2013-02-17 21.10.52.jpg2013-02-17 21.12.14.jpg2013-02-17 21.11.20.jpg2013-02-17 21.12.45.jpg
rascal1
452
Marino, Dublin
Bits to change to suit VW are readily available from eurocarb.. CB bellcrank for IDFs comes with the bits that bolt onto the carb spindles.. I am currently fitting a pair of 36IDFs to a new injin for the van.. They are nice carbs..
183
I was just thinking that - it's a common conversion, and not much drama.
