Hi, Don't have, these are as scarce as hen's teeth and if available wd be expensive. Alternative solution, if 60s engine or later, change dynamo stand from 90mm 6v type to 100mm 12v type and
install 12v dynamo, 30A or 38A, or fit alternator. The 100mm alternator has more of the casting cutaway to fit alt Vs dynamo. Have all 3 types refurbished Bosch origina. For visual effect drill & tap dynamo case along top bolt going inside end to end and screw 14V regulator
on top, looks like 6V setup. Give a call 0857827537 to discuss, if you wish. Regards, Eamonn
