[Wanted: Parts] Rear Drums 130 Porsche Pattern
philk
208
Wexford
www.goldmedalsafetypadding.co.uk
I'm looking for a pair of rear drums 130 pcd for fuchs wheels.
The threads in mine have gone and possibly the easiest way out is a new pair.
If anyone has a pair lying around please let me know, new or used - not bothered
Or --- can anyone on here supply a re-drilled pair to me?
Cheers
Phil
you could try your local precision engineer to have them redrilled. If they're aftermarket drums with just the 5x130 pattern on them then they'll have a reinforcing web all the way around the inside of the front face, where the holes are drilled through. The redrilled stock VW drums only have a "four fingered" reinforcing web where it's needed for the 4x130 pattern. If they're aftermarket drums you'll be safe redrilling new holes in the spaces between the original damaged ones.
