[Wanted: Parts] radiator pipe
leebo
March 17, 2014
24
dublin
Howdy folks ,i went to have a look at a T25 earlier unfortunately the plastic pipe that runs under the chassis and connects to the radiator had a small split in it and was leaking .so no test drive .Is it hard to source these or could I use some sort of repair paste/ something else. Thanks folks
Tim
2,951
238
Midlands
www.boards.ie
If its the supply pipe from the rad to the engine, the rubber supply pipe is readily available in any motor factors. It needs a feed and return, so two pipes. I bought a full role for 25 euro, 6 months ago, for my 87 T25.
leebo
March 17, 2014
24
dublin
thanks Tim ,its the hard white plastic pipe it looks like ordinary 1 1/2 waste pipe.where can it be bought?
Tim
2,951
238
Midlands
www.boards.ie
I dont know why hydrodare pipe is connected to the rad to be honest. If its the rad supply pipe, or return, it should be in standard automotive water supply pipe.
Hydrodare pipe can be bought in 6 metre lengths in a builders supply, if you do intend using it. Be careful as some suppliers will have both metric and imperial sizes in stock, which vary.
leebo
March 17, 2014
24
dublin
cheers mate, no its not hydrodare its a white plastic pipe ,original I presume ,well it had a V.W part no. on it anyway. No longer needed anyhoo , the lad changed his mind and has decided to keep the van now, after me driving to wexford to look at it. I'm gonna try sell the m.k1 golf now and buy a decent T 25 . Thanks again
