[For Sale: Parts] Porsche Wheel and adaptors
cherrybomb
8
ireland
For sale seventeen inch Porsche wheels set of 4 comes with tyres on but needs tyres as little thread left. A couple of scratches comes with centre caps 250 euro
Set of 5x112 to Porsche adapters suit Late bay, T25/T3 and T4 100 euro 039.JPG040.JPG
johnnyg
1,524
Athy
What width are they and offset and do u no if they will fit under stock 1303 wings thanks
If they are 7" wheels you will need an et of 50 to 55 to sit under stock arches on a two bolt setup, using slimline struts as well.
Three bolters may allow an et of 40,but I'm not 100% sure on that.
also, the particular adapters above are for 5 x 112mm where as you would need a 4 x 130mm for a 1303 hub (unless you've changed to a 5 x 112mm).
cherrybomb
8
ireland
HI the wheels are all the same width 7.5j the et is 23 not sure if they would fit under the arches of your car.
Thanks Ben
