[For Sale: Parts] parts clear out
darragh
1,453
Co. kildare
open to offers on all parts except the engine lid lock, that has a home already
walshe
569
athy
How much for the hub caps and track rods? and is that a left hand side mirror?
darragh
1,453
Co. kildare
rhs mirror
ball joints are the smaller ones for earlierish beetle
hub caps are a little rough but will polish up good i have 8 and you should be able to get 1 good set outta them so
just do a little research on the price and make me a fair offer :) ,hard to get good chrome these days I here lol
Brian Raftery
Administrator
3,985
122
Kiltimagh Co. Mayo
darragh;163297 hub caps are a little rough but will polish up good i have 8 and you should be able to get 1 good set outta them so just do a little research on the price and make me a fair offer :)[/QUOTE said:
I'll start the bidding at €10 each
rascal1
452
Marino, Dublin
What is the bore size of the exhaust.Are you in Naas someplace..I work in Kildare sometimes. There seems to be an unusual pipe at the heat risers.Has me curious.
rascal1
452
Marino, Dublin
Manifold pre heat pipes.
Yes you are quite correct. But if you look closely at the one on the left hand side,it has a small pipe going to right. There also appears to be a pipe coming from the bottom of the left heat riser. The hole in the left hand side is also smaller. This makes this a very unusual 4 into 1 manifold where the heat riser will work correctly.
Tim
2,913
219
Midlands
www.boards.ie
You are right.........I should have gone to specsavers:D
could you have a look when you get a chance ? is it a bare case ? it`ll either have AS41 or AS21 underneath where the pushrod tubes enter the case
