MkII Golf Driver 1.6
183
1990 MkII Golf Driver, 1.6. UK imported in '07, now on KE reg. 130 odd k miles (will check exact mileage later).
  • First NCT'd September 08, just needed two new rear shocks and one new headlamp, and headlamps adjusted. Expires at the end of this month.
  • New timing belt and pump fitted in August '09.
  • Was a daily driver until November '09, but replaced with a Focus and has sat unused since.
  • Clean interior, no rust (apart from a stone chip or two), polishes up well.
  • Near new tyres, on the stock steel rims.
Bad points;
  • Gearbox groans a lot, but doesn't jump out of gear, I suspect the diff approaching the end of it's life.
  • Exhaust has cracked and will need welding.
Drives well, stops fine but does need some attention as mentioned above.
€500.
With a little love can look like this again -
16" Wolfrace wheels as pictured available separately, in need of light refurb, for €100 (3 usable tyres).
Weber carb kit also available for €95.
If you want any specific pics please ask.
Some history, reciepts and MOTs etc. -
