[For Sale: Parts] for sale: full set of bug me workshop reference videos and tv/video combo for garage.
buggyboyshane
1,306
up north :)
perfect for garage, stick tv in the corner, play, pause, work, play, pause, work ec etc :)
this covers every area youll ever need for restoring a bug. :) for full listing look below.
look like this:
Guys my trusty set of bugme videos has come of age and is ready to move on. looking 50quid for the lot, excellent condition all in their cases etc. want to sell as a set.
for 50quid extra you get a remote combo tv/video in perfect clean as a whistle condition, and about 20 videos ranging from clarkson, to indiana jones series, blade and whole lot more (which ill name when i find them). and herbie set.
VOLUME #1 - GENERAL MAINTENANCE - Over 1 hour of easy to follow instruction: Including:
VALVE ADJUSTMENT
CLUTCH ADJUSTMENT
FAN BELT REPLACEMENT & ADJUSTMENT
SPARK PLUGS
DISTRIBUTOR
CARBURETOR MAINTENANCE
AND - MUCH - MUCH MORE!! (HOW-TO VIDEO LIBRARY)
VOLUME #2 - MOTOR REMOVAL & CLUTCH SERVICE - Over 1 hour of easy to follow instruction, including:
PULLING MOTOR
REPLACING:
CLUTCH
RELEASE BEARING
CRANK-FLYWHEEL SEAL
REAR TRANSMISSION MOUNTS
CLUTCH CABLE (HOW-TO VIDEO LIBRARY
VOLUME #3 - BEETLE - GHIA COMPLETE ENGINE REBUILD - Over 2 hours 38 min. of easy to follow instructions, including:
TEAR DOWN
CLEAN UP
INSPECTION
ASSEMBLY (HOW-TO VIDEO LIBRARY)
VOLUME #4 - BRAKE SYSTEM - Over 1 hour 45 min. of easy to follow instruction: Including:
BRAKE SHOES
WHEEL CYLINDERS
BRAKE LINES
MASTER CYLINDER
DRUMS & ROTORS
EMERGENCY BRAKE
WHEEL BEARINGS & SEALS (HOW-TO VIDEO LIBRARY)
VOLUME #5 - TRANSMISSION REPLACEMENT - 1 hour of easy to follow instructions, including:
SWING AXLE & I.R.S
REPLACING AXLES
SHIFT HOUSING
C-V JOINTS
REAR AXLE BEARINGS
REAR AXLE SEALS
VOLUME #6 - FLOOR PAN REPLACEMENT - 1 hour 45 min. of easy to follow instructions, including:
REPAIR
REPLACEMENT
BODY REMOVAL
BASIC WELDING
VOLUME #7 - HEATER CHANNEL REPLACEMENT - 1 hour 40 min. of easy to follow instructions, including:
HEATER CHANNEL
LOWER DOOR POST
LOWER QUARTER PANEL
VOLUME #8 - 17-2000CC BUS ENGINE REBUILD - 3 hours of easy to follow instructions, including:
TEAR DOWN
INSPECTION
ASSEMBLY
WIRING HARNESS REPLACEMENT
IDENTIFYING INDIVIDUAL WIRES & TERMINALS CHANGES OVER THE YEARS 61-79
In this video we start with installing a complete wiring harness in a "63 bug. Then we show the differences in the wiring as they progress over the years including the Super Beetle. We also show how to make certain modifications necessary because of items now obsolete. There is much information here that you will not find anywhere else. After watching this video you will know where each and every wire goes and every connection.
and a demo tape as well with a wee bit of everything.
