[For Sale: Parts] 1300 engine: ebuild candidate
2,315
I have this 1300 engine here that I'm not going to get too involved with as it's not something I *need* at the moment and I already have too many projects ;)
it's a 1300 twin port with dog-house oil cooler. twin hot-spot pre-heat pipes.
it's complete but looks in a sorry state as all the tinware is surface rusty.
it has an alternator for use with an external regulator
no carb
SVDA distributor also in need of a little lubing up.
thermostat present and not burst
all standard tin present, right down to the "Hoover bit". No rear tin over the exhaust :(
exhaust fooked with rust.
heat exchangers are usable
It is stamped "AR" engine code
The reason I'm calling this a "rebuild candidate" is that I've removed all the tin and the cylinder heads and I think the rings are catching inside the cylinders preventing a full revolution by hand mean that it'll need a little love before being put back into service.
So, with that in mind, it's for sale cheap at €150 for the lot. Ideal as a core to send off to your friendly local engine builder oop norf for the treatment while you still use your existing engine.
with the heads fly-cut this could be upgraded to 1600-spec easily. Talk to Caddy about that...
